Topic: [RESOLVED] Where is database clean.....
I have a ton of missing or broken file links (square orange box around them) and I can't find the "Clean/Check/Fix" database, and I've RTFM (Read The Freakin' Manual), which states nothing.
geposted Thu 15 May 14 @ 2:58 pm
The database in version 8 maintains itself. But if you find you have a lot of tracks that a 'missing' you have an option to remove them
geposted Thu 15 May 14 @ 3:02 pm
Outstanding. Did the trick. Thank you!
geposted Thu 15 May 14 @ 4:03 pm
