Mac OSX 10.9.3
VDJ 8 Build 1752.644
If you pause a song midway, then UNLOAD the song from the deck (by right-clicking the stop button), The progress ring around the record, stays lit up as if you are still half way though a song even though there is no song actually loaded on the deck. The spinning pointer on the record also keeps pointing in whatever direction it left off.
geposted Thu 15 May 14 @ 9:30 pm
Reported. Thank you for noticing.
geposted Fri 16 May 14 @ 12:41 am
