Topic: Key Control Panel
DanCattPRO InfinityMember since 2013
I can only find this available when in 2 deck or 6 deck mode - is there any reason why this is not available in 4 deck mode or am I simply being a numpty and not finding it ;)
Cheers!
geposted Fri 16 May 14 @ 5:11 am
Nope you are not being a numpty.... I cant find it on the 4 deck skin either.
HELP
Where has the key drop down selector gone on the 4 deck skin?
geposted Fri 16 May 14 @ 6:31 am
Fingers crossed it will magically appear after a bit more tweaking behind the scenes.
geposted Fri 16 May 14 @ 7:23 am
pseftPRO InfinityMember since 2009
I found it guys... in the deck display under where it says TAP, there's a drop box
geposted Mon 09 Nov 15 @ 3:08 am
That's the 2 deck and 6 deck. These guys are looking at the 4 deck, and I don't see it either. It's missing on the Zoom 4 deck also.
geposted Thu 12 Nov 15 @ 8:07 pm
ummmm... yeah. no comment.
that was my problem in the 2 deck, couldn't find it and found it few days later when I was on here... took me like 3 days but I found it :D
geposted Fri 13 Nov 15 @ 5:48 pm
