macbook year 2011 i5 8 gb memory 1tb sshd harddrive intel hd grafics 288 mb
vdj build 1761.644
vdj work fine for a few minutes then cpu raises, temp raises and if i don't close vdj macbook crash
other times vdj works fine, trying to search a song vdj crash and restart. if i type "tita" like in titanium vdj freezes.
the little bug i had i vdj 7.4.1 is gone in vdj 8.
looking forward to get vdj 8 running smoothly.
regards
kent
vdj build 1761.644
regards
kent
geposted Fri 16 May 14 @ 6:00 am
btw after freeze i have to use option-command-esc to close vdj.
geposted Fri 16 May 14 @ 6:01 am
