showcoverfordragdrop
geposted Sat 17 May 14 @ 6:58 am
Found it, thanks.
geposted Sat 17 May 14 @ 10:27 am
Hi, can you let me know where the "showcoverfordragdrop" cant see it
thanks
geposted Sat 17 May 14 @ 10:48 am
thanks
thanks
it's ok, thanks got it, cheers ;))
geposted Sat 17 May 14 @ 10:50 am
RetrodiscoUK wrote :
Like I said, I don't use automix, I use a sidelist to line up my ideas, the regular sidelist has no option to remove the tracks automatically when played, the automix list does, and can be used as just a list with automix turned off, however it still says automix. If sidelist had the option too, it would be great.
+1 Yes please,
delete from Sidelist if played not if drag to Deck like V7 (AutomixList).
geposted Thu 22 May 14 @ 3:55 pm
Sorry, i found the Solution in Expert Settings.
![](/image/20877/136558/Unbenannt.png)
The V8 is a great tool.
geposted Thu 22 May 14 @ 5:28 pm
Automix / Sidelist I'm having a few issues with the automix playlist. Sometimes i can drag a file and it doesnt show up. but i drag it over again and it then shows 2 of the same file all of a sudden.
Automix playlist When using the automix playlist. once i started the other player going and set someone to sing. I skip through what was playing on the other deck to get to the beginning of the next track in the playlist automix and instead of it staying paused like i had it. it starts playing instantly once i have used the jog wheel to get to the beginning of the next track. this is rather annoying as it sets the transition going on the main extended screen and puts the singer off. in vdj 7.4 this always stayed paused until i pressed play or hit a cue point.
geposted Sun 25 May 14 @ 6:11 am
I've noticed songs not appearing and then twice. It's if they are scanned, they are there but the text doesn't appear.
geposted Sun 25 May 14 @ 9:33 am
Is there any way to move/drag/copy tracks from the Sideview/Sidelist tab into the Sideview/Automix tab?
I tend to, or would like to use the sidelist as a holding tab and the automix as my ordered playlist tab regardless of automix setting which I do use for buffet time etc.
geposted Mon 26 May 14 @ 6:43 am
as far as i know you can onyl copy to sidelist / automix straight from the browser window...if wrong please correct...
geposted Mon 26 May 14 @ 6:49 am
Hi again Rob,
That certainly seems to be the way it works at the moment.
geposted Mon 26 May 14 @ 7:06 am
You can set (in config) the sidelist to be at the bottom of the browser a la VDJ 7 if that makes any difference.
showHorizontalSideList = yes (needs VDJ 8 to be restarted to work)
[edit] yes, I just tried it. When the sidelist is at the bottom (bottomlist?) then you can drag tracks from there to Automix.
geposted Mon 26 May 14 @ 8:10 am
Nice groovindj. Thanks a milion.
geposted Mon 26 May 14 @ 8:21 am
I guess it's just the stigma of having an automix list up on screen and looking like a lame DJ who uses automix all night.
Do you have nosey people looking over your shoulder at everything you do? .........or is this just your perception?
Me personally I couldn't care less. I have always used the playlist/automix to store requests and ideas of tunes I want to slot in. With the added bonus of clicking autoplay if I needed a bathroom break ................and still be awesome lol (I NEVER do, just sip water all night).
geposted Mon 26 May 14 @ 8:44 am
what about when you load a track and then change your mind and put another track in the player. in vdj 7.4 the rejected track went into sidelist and was great. could always play it in a bit if required. now it just gets ditched and you have to remember what you ditched.
geposted Fri 30 May 14 @ 5:18 pm
Here is another trick,
You can add a shortcut or custom button as 'switch_sidelist_playlist'
It switches the content of the two lists.
This might be useful in many cases, for example i like to use the automix list also as my list editor and have one set of shortcuts and not for both lists.
So i simply swap the lists, do my edits like 'remove played', then i switch them again.
geposted Fri 30 May 14 @ 5:38 pm
saveUnplayedToSidelist : yes !!
geposted Sat 31 May 14 @ 9:35 am
thanks
geposted Thu 05 Jun 14 @ 12:51 pm
