Topic: Automix point
Hi, One thing that I've always thought needed changed is the size of the automix point I think it needs to be a bit bigger or have a tab attached to make it easier to click on without accidentally jumping to the end of the track thats playing
geposted Fri 16 May 14 @ 7:42 am
Jason KPRO InfinityMember since 2007
Can't you open the automix editor and just slide the track over? Haven't played with it much, so I'm not sure.
geposted Fri 16 May 14 @ 7:44 am
Yes but that is just way to many steps, when in v7 all you had to do was drag and your done. Also i do not use a mouse when I dj. In V8 you can just right click on the song and select mix now. Or even use one of the user custom buttons and make it a mix now button which is what i did.
Keep em dancing
geposted Sat 17 May 14 @ 12:37 pm
