Topic: Bug in Video Audio Only Visualization
There is a bug in the Video Audio Only Visualization in options. The visualization still plays even with video. It was designed to play only if there is no video unless you manually activate it. I am video DJ and use this tool with version 7 pro.
geposted Fri 16 May 14 @ 7:57 am
TantrixPRO InfinityMember since 2013
Set the visualization you want in the "Master Effects" under the "Master" tab and NOT under the "Video" tab. I had the same issue. It appears that any setting changed under the "Video" tab is all inclusive and takes priority over video streams. Hope this helps.
geposted Fri 16 May 14 @ 9:31 am
Yes it helped. Also, I switch the video crossfader from auto to link to both crossfaders and that helped as well. Thanks!
geposted Fri 16 May 14 @ 3:05 pm
Man you got me out of a pickle brother thnx worked like a charm.
geposted Wed 31 Dec 14 @ 8:22 pm
