Topic: SONGPOS vs LINEIN
I have a few of my illuminated buttons on my controller, as well as a custom Icon in the skin, set up to blink when songpos_remain is 30 seconds or less (To make sure that I'm aware that the current song is running out, in case I'm searching for another song, or somehow got distracted).
With Version 8, they are constantly blinking when Linein is activated. with Version 7, they were not.
I know I can use vdjscript to program them not to activate when Linein is active, but I was curious if this is a bug, or just a normal change in functionality for V8.
(I Don't want to reprogram a bunch of stuff if it will get fixed in a patch anyway)
Thanks
geposted Fri 16 May 14 @ 8:20 am
