Topic: MacOS and VDJ8 problems
raynetPRO InfinityMember since 2006
MBP 8,1 13" OSX 10.9.3 2,3 GHz Intel Core i5 4 GB Ram
VDJ 8 B1761.644
if VDJ runs only with the internal HDD now I have found no problems, but I close my WD 2TB (My Passport 071D) with Firewire, then he gets hot and then stops responding or freezes ... (must be the process manually kill)
Clearly, I do not get a crash report: (
I have not connected a controller or sound card, only the ext HDD Firewire ...
I now have the VDJ8 also deleted the setting.xml, reloaded and installed ...
here is the video for info what happens:
http://www.ray-net.at/Musik/Virtualdj8.avi
I start only VDJ8 that needs to talk a bit to start up, no idea what is being process ...
I click on the external HDD then VDJ includes equal time short, then I click again on the ext HDD
pulling a title in the player (I have not done in the previous) but when I click on Andrea Berg it's over ...
With V7 there was no problems ...
geposted Fri 16 May 14 @ 9:31 am
