Hello ! Need help with proper using A & B and master effects buttons with ns7 II
is there a manual only for ns7 II to see how to use :
1.master A,B /transition or effects ,how to scroll through the master effects by controller not by mouse
sometimes i can't turn on master section effects like transitions or audio video effects ...i can do that only by mouse !
2: is there an option to use all of 3 buttons for effects just like they look like on my ns7 II and on original virtual dj skin ? picture 1![](/image/8224/135613/ns7 II.jpg)
3: is there option to unload song or video from player with mouse or controller ?
i had crash when accidentally right click on cue button on my player 2 ---> video from my player A appears on player B and numark freezes,audio was playing but video freezes
could not reproduce it again.
another problem was that after using slicer my video stopped and audio keep playing but could not stop it by cue button...it looks like it was playing somewhere in preview mode but i couldn't find way to stop that .
i would like to read manuals how to use all of this and not asking for help every day :)
geposted Fri 16 May 14 @ 9:56 am
To No 3: Rightclick and hold the stop button of a deck for a second or so.
Edit: And a manual is in your My Documents/VirtualDJ folder.
Just not NS7 specific.
geposted Fri 16 May 14 @ 9:59 am
geposted Fri 16 May 14 @ 10:00 am
to n.3 is there another way or i must use mouse with controller ?
i found manual but i got only ns7 for every day use and cdj 2000+djm 2000 in the club.
geposted Fri 16 May 14 @ 10:01 am
You could map a button with the action "unload"
Or "deck 1 unload".
Or "deck 1 unload".
geposted Fri 16 May 14 @ 10:03 am
thank you PachN ! i go map 'unload'
I would be grateful for any help concerning the case 1 and 2
geposted Fri 16 May 14 @ 10:13 am
case 3 solved ! shift+load = unload :)
geposted Fri 16 May 14 @ 10:21 am
Answer to your 2nd question.
Just going to respond to the capacitive controls... I just got the NS7ii yesterday and was playing around with it, did you try pressing and holding the shift button while also pressing the touch button. This will activate all capacitive buttons (FXs, EQs and Filter). Only pressing the touch button will only activate the FXs capacitive buttons.
The FX buttons work like this on VDJ8 (from what I have seen so far)
FX1 Button = Triggers FX
FX2 Button = Search back through FX list
FX3 Button = Search forward through FX list
FX1 Knob = Change first parameters of selected FX
FX2 Knob = Change second parameters of selected FX
FX3 Knob = Change third parameters of selected FX
If you press down and hold the shift button while pressing the Beat/Mode button you trigger Multi-FX in this case:
FX1 Button = 1 FX and FX1 Knob = 1 parameter of that FX and so on...
Have you read the NS7ii manual? It has a lot of info there and can get a sense on how things should work (at least that's how it should work for Serato, then you can kinda see how things are being implemented on VDJ8)
- dee_jay_boy
- dee_jay_boy
geposted Sat 17 May 14 @ 6:30 am
