I am stuck in an endless look, asking if I want to upgrade.
I say yes, it closes and asks me again.
Suggestions?
Suggestions?
geposted Fri 16 May 14 @ 10:48 am
I had to download the new version from the website and install.
Works again.
Works again.
geposted Fri 16 May 14 @ 12:58 pm
Back in the endless loop, asking me if I want to install the new version.
geposted Sat 17 May 14 @ 8:43 am
Some others had this yesterday.
Please open task manager and ensure that there a no process or instances of Virtual DJ running silently in the background. Then try again.
geposted Sat 17 May 14 @ 8:46 am
On a Mac... (no task manager). Only one version open on Utility Manager.
only one version open... just keeps looping.
Been reporting this for a few days.
geposted Sun 18 May 14 @ 8:23 am
geposted Sun 18 May 14 @ 8:24 am
Also, the current build is not on the download link.
geposted Sun 18 May 14 @ 10:48 am
This just started happening tonight with build 1900 (Mac).
Stuck in the "do you want to upgrade?" loop.
Tried rebooting and still doing it.
Downloaded installer for VDJ8 and reinstalled over the existing install and same problem.
I've deleted the "update1900.ready" and "changelog.txt" files from the cache directory and it downloads them again on the next restart, then goes into the "wanna upgrade" loop again.
if I hit YES, it just loops asking over and over. if I hit NO, then it runs the app with the prior build (1897.749).
Has anybody figured this one out?
Thanks
Thanks
geposted Wed 30 Jul 14 @ 10:49 pm
the bug is present only in the Beta build. There is no issue with the Public one. Please see the Regression forum.
Do not use this forum for the beta builds.
geposted Wed 30 Jul 14 @ 11:25 pm
I wasn't even aware that was a beta build (or that I was getting betas). I just went into my account and turned off the "beta builds" checkbox so it won't try to download it again.
geposted Wed 30 Jul 14 @ 11:49 pm
+1
geposted Thu 31 Jul 14 @ 1:44 pm
