Topic: Loop Out bug
Hi, when using the LoopOut effect, it works as it should except when the song actually ends it jumps to playing again and applies the brake effect!
geposted Fri 16 May 14 @ 11:24 am
lincol2PRO InfinityMember since 2011
in my case notices when loopout is activated you can hear the loop out effect in the background, But the song continues to play. Whereas in 7.4 it loops out and stop.
geposted Sun 25 May 14 @ 1:49 pm
