Topic: a few questions after gigging
worked good all night just a few questions. 1 before when you sorted your folder by say bpm then sorted by date created my tracks would be sorted by date first then by the bpm. Seems to not remember the first sort anymore?2 do i haveto keep going under options to show and hide music or video inmy playlist? 3 where is the volume for the sampler?
geposted Fri 16 May 14 @ 12:16 pm
The sampler volumes are only visible in list mode, and then only when the volume column is enabled.
In pad mode you can't access volume.
geposted Fri 16 May 14 @ 12:20 pm
I said this in the "First Impressions" form but just to clarify I really really want this option back please.
geposted Fri 16 May 14 @ 5:38 pm
