so far I like VDJ8 however i'm having a huge problem scratching using the jog wheels on my VMS4. When I move the jogwheel anticlockwise in terms of a backspin there is no sound just when i scratch forwards does the sound of scratching appear?? can anyone tell me the recommended setting to scratch with VDJ8 and on a VMS4? I have to say though the crossfader response is so much more accurate and fast when I cut on the vms4 than the previous vdj7 version.
honestly I haven't had much time to play with this new pre-release.
all opinions/help welcome!
geposted Fri 16 May 14 @ 12:16 pm
Do you have smartscratch set to yes?
If so, switch it to no.
geposted Fri 16 May 14 @ 12:18 pm
in fact i have it set to "YES" just double checked.
geposted Fri 16 May 14 @ 12:21 pm
thanks Groovin!!! I turned smartscratch off and it works!
geposted Fri 16 May 14 @ 12:24 pm
pls give some feedback on what you think of the new TCV in the thread
http://www.virtualdj.com/forums/187224/VirtualDJ_8_Pre-Release_Forum/Timecode_users_________.html
geposted Fri 16 May 14 @ 2:30 pm
Whilst VMS4 can manager timecode - this issue was not timecode related.
Please stay in the other thread for timecode - thanks ;-)
geposted Fri 16 May 14 @ 2:36 pm
