Since the last automatic update, VirtualDJ doesn't want to work anymore, when I start it Windows immediately says that it stopped working and closes it
Windows 8.1 64 bits - Intel Core i7 - 12 GB RAM
geposted Fri 16 May 14 @ 12:43 pm
If I were you, I'd try uninstalling it then download the latest installer package from the download link and start over.
Say 'no' to removing your settings, data etc. if you want to keep that.
geposted Fri 16 May 14 @ 12:46 pm
Okay I just did it, it also installed another new version, everything works perfectly, thanks for the advice !
Oh btw a nice feature, I changed computer since a very little time, I imported my cache files from my USB key to the Cache folder of VDJ, they're in the software ! I think it was not the case before, only problem is everything appears twice in the VDJ browser
geposted Fri 16 May 14 @ 1:19 pm
