Topic: scratchwave not visable
I clicked on the scratch tab I dont see any waveforms How do I enable ?
geposted Fri 16 May 14 @ 3:14 pm
Bueller........ Bueller........
geposted Fri 16 May 14 @ 7:30 pm
OK, obvious questions first.
What skin?
Do you have tracks loaded to the decks? What format are the tracks? Are they cued to a part of the track which contains audio? Can you hear audio (but just can't see the waveforms)? Do these same tracks load, play and display waveforms OK in VDJ 7?
geposted Fri 16 May 14 @ 7:39 pm
The Vinyl skin and The vdj8 skin. I click on scratch on the vdj8 skin there are no scratchwaves. On the vinyl skin no waves either. I've loaded mp3. & mp4 audio plays fine. Everything works fine just can't see any scratchwave
geposted Fri 16 May 14 @ 9:38 pm
Do you see anything at all in the scratch windows? For example if your gains are turned down, you'll only see a line.
What's your system? PC, Mac, OS?
geposted Sat 17 May 14 @ 7:40 am
did you turn off hardware acceleration of skin in the options ?
geposted Sat 17 May 14 @ 8:05 am
