and a small bug: if you press on TAP Rapidly the vdj8 crash, win 7 pro
geposted Fri 16 May 14 @ 3:58 pm
Where are you tapping to cause the crash?
The scratchwave with have more features added.
geposted Fri 16 May 14 @ 4:09 pm
the TAP Button right to the BPM
geposted Fri 16 May 14 @ 4:15 pm
Not sure why it has crashed, but there is no need to repeatidly tap the button.
Please read the manual for BPM.
geposted Fri 16 May 14 @ 4:22 pm
i tap it to get the correct bpm and after 4-5 taps the vdj8 crash
"The scratchwave with have more features added" what did you mean ?
geposted Fri 16 May 14 @ 4:37 pm
Team has your crash report already (automatically uploaded) so hopefully will be fixed soon.
As for the scratchwaves, currently they dont show the gridlines by default and if you happen to use some custom skins that do, its actually a "trick" which requires to manually adjust both rhtyhmwave and scratchwaves (via a dual slider) in order those to have the same speed.
So for the default skin we have chosen not include this "trick" and hopefully the scratchwave will have its own native grid lines soon.
geposted Fri 16 May 14 @ 6:31 pm
Thanks.
Another question, Is it possible to see in 2 decks screen both the elapsed and the remain time ? i Really got used to it in ver.7
and how to keep the key to allways show the Lettersׁ (AM) and not the Code (08a) as Default ?
geposted Fri 16 May 14 @ 6:57 pm
Both are not easy. They require kind of surgery on the xml code :)
Better start looking for a custom skin that offers them or if u still wanna try i could possibly guide you with some steps, but not sure if you could follow them.
geposted Fri 16 May 14 @ 7:02 pm
When you got both have a good indication of how long the song is played and how much remains Without touching the computer...
One more thing how do i config the 8 to load all of the long mix like the "infinite" that was in ver7 ?
geposted Fri 16 May 14 @ 7:12 pm
setting MaxPreloadLength ..set to -1 (Infinity), but its not suggested. Better define a larger value in mins
geposted Fri 16 May 14 @ 8:42 pm
ok new i set it to 90...
geposted Fri 16 May 14 @ 8:53 pm
how to keep the key to allways show the Lettersׁ for e.g (AM) and not the Code (08a) as Default ?
geposted Fri 16 May 14 @ 10:00 pm
Any suggestions?
geposted Sat 17 May 14 @ 11:54 am
