Forum: VirtualDJ Plugins
Topic: Hot to use Video Effects .ini to .bundle? (MAC)
I realize that the plugins in Virtual DJ 8 for mac is now .ini,
i wonder to use this plugins in virtual dj 7 (mac) that use bundle. I try to use the ini files but dont work.
Why i dont use virtual dj 8 ?
When playing a video in a deck, and active one video sample in the banks, the audio makes a little noise, like that in vdj other old versions when you scroll the mouse, (tha safe button in preferences was enough) Now i try to change the performaces sets and the "noise" still.
geposted Fri 16 May 14 @ 4:24 pm
All Mac plugins are bundles. The ini files are saved settings for plugins.
geposted Fri 16 May 14 @ 5:29 pm
now i realize that some video effects,( i dont know if are all plugins ) dont apear in the virtual dj folders. I made a search for colorize or spectral plugin and dont find.
Anyone could make a teste if this video effects could work in vdj 7?
geposted Fri 16 May 14 @ 7:15 pm
Some v8 plugins are internal to the software, so can't be used in v7. I wrote spectral and I didn't create a v7 version.
geposted Fri 16 May 14 @ 7:26 pm
i will try to resolve this problem thats "freezing audio" when i use a video in a deck and active a video in a sample bank
geposted Fri 16 May 14 @ 7:34 pm
