Hi, I just tested out the new Backspin and I don't think it's as good as the older plugin we used in version 7 found here (http://www.virtualdj.com/addons/26/Backspin.html).
The old backspin (with a small b), you could press it and just before your track came to an absolute stop, you could release it and the track continued on - totally cool effect.
The new one, after you press it, it backspins but the track stops completely. Could the new effect be altered to continue on if you "release" it in time?
geposted Fri 16 May 14 @ 8:43 pm
Wouldn't this be the case if you use slip mode first?
geposted Sat 17 May 14 @ 2:25 am
