im am using a pioneer cdj 400 and djm 600 not a controller mixer now if the limiter kicks in i have less controll of it and That is a problem, My question is this: can you make the master vol Remember my config that sound good and not close to the limiter Because I dont have control over the lines gain in the software like in a controller mixer, lets say 95% is my "sweet spot" and i want the 8 to Remember it evrey time i start it, Is it doable ?
geposted Fri 16 May 14 @ 8:51 pm
keyboard offers an ONINIT key in version 8. You can define there the desired master volume level..e.g. master_volume 70%.
goto CONTROLLERS tab of Config .. select the keyboard from the top left list and then scroll down to the last available/mapped key of the keyboard and use the last empty line to select the ONINIT key and assign an action to it.
geposted Fri 16 May 14 @ 8:55 pm
ONINIT key ?
geposted Fri 16 May 14 @ 9:00 pm
![](/image/63080/135700/keyboard mapper.png)
geposted Fri 16 May 14 @ 9:06 pm
Works great thank you very much !
Last question... What does it mean ONINIT ? Or what his role ?
geposted Fri 16 May 14 @ 9:13 pm
