As you can see on this video (I've tested it dozens of times and it always happens)
https://www.dropbox.com/s/yjehlkme75c7tp8/rythm-waveform-window-CRASH.mov
When playing carelessly with the Rythm Window / Waveform slider or wathever it's name is, the mouse goes wild.
Once this happens two mayor things occur:
1) The mouse Y-axis goes crazy, respecting it's X-axis and no harm is done to VDJ8 (at the second 6-7 of the video),
2) The mouse goes to a corner of the screen, the rythm window goes crazy (it updates from bottom to end many times) during 0.2secons, and VirtualDJ8 crashes and exits. (at second 10-12 of the video)
- It happens on both decks (I've tried only with two)
- If there is no song loaded, no movement is applied, so it doesn't crash.
I've got a Macbok Pro 13 retina Late 2012 with 10.9.2 and VDJ8 1761.644 (I'm using the built-in trackpad moving it horizontally 3cm to left and right, and the built-in soundcard)
geposted Fri 16 May 14 @ 9:06 pm
I confirm that this DOESN'T occur on windows! Only happens on Mac OS X
geposted Sat 17 May 14 @ 11:39 am
