Topic: load button on ns7 glitch.
when you use the load button on the ns7 it makes the track currently playing make a backspin noise.
geposted Sat 17 May 14 @ 3:51 am
anyone else notice??
geposted Sat 17 May 14 @ 1:28 pm
Hello
geposted Sat 17 May 14 @ 6:05 pm
lol, hello fellow NS7 user, I copy over... Can't say I've had that happen and I've been on the thing daily since last Sun.
geposted Sat 17 May 14 @ 6:33 pm
thanks for the reply. worked in 7. you notice the bug when scratching.
geposted Sun 18 May 14 @ 2:09 pm
Yes, its obviously not ready. All the feedback will hopefully get us a finished product soon. Its like getting a new Corvette before you get your license. All you can do is fire it up and sit in your driveway.
geposted Sun 18 May 14 @ 3:34 pm
Thanks for the reply. Just figured someone from VDJ would post something like. We are aware and working on it or something. Glad to know I am not crazy
geposted Sun 18 May 14 @ 4:12 pm
Same exact problem on my ns7
geposted Sun 18 May 14 @ 11:53 pm
