Topic: Effect Reset on Load (and mixer)
prezPRO InfinityMember since 2005
I can not locate any setting to reset the Effect (to Off) on load
nor can I find a way to set the mixer (bass, mid, high) back to default (zero) on load of new track.
in VDJ 7 it was located in the options, I looked in all of the options but could not locate any way of setting those values to reset on load. Am i overlooking it? is it in another area?
geposted Sat 17 May 14 @ 8:01 am
No got it in front of me but eqResetOnLoad
Try loading options tick advanced and search for reset.
That will give you your available options.
geposted Sat 17 May 14 @ 8:06 am
thanks djtouchdan...
I had the Advanced checked earlier but couldn't find it, but was searching for effect, and mixer... that's why I never saw them.
geposted Sat 17 May 14 @ 8:12 am
No problem.
geposted Sat 17 May 14 @ 8:16 am
