Topic: Removing Tracks From Automix
Hi, first I would like to say thanks for the major update of the world’s best DJ software
I’m maybe missing something but in vs7 when adding a track to the Automix area and if i decided not to use one of the tracks all you had to do was drag the track back over to the song list area, now if I want to remove a song from my list of the Automix tracks I have to right click on it then go down to remove
Is that correct, no problems if it is but it was quicker the old way
Many Thanks
geposted Sat 17 May 14 @ 10:22 am
There are a few useability issues in that area right now it seems.
geposted Sat 17 May 14 @ 12:00 pm
i like the old way
geposted Mon 23 Jun 14 @ 10:55 am
