Scratch Waves are gone for some reason.... and Default wave forms are dark????? is this a bug or setting somewhere that i switched by accident...???
Also.... deck A is Blue on the vertical UV meter.. deck B is Red until the tipy- top and it show yellow...... Why is is it only on deck B and not A (the yellow??? Personally I like that.. the fact its letting you know "The track is Hot dont puah the gain anymore"
Btw the wave forms WERE working fine! The UV Meter always did that. So I dont know if its a setting or something else..
Ive also noticed I havent had any updates in the last, at least 2 or 3 days.. I purposely shut it down and back up every day, more than once some times KNOW that its a Pre Release and Updates will be needed, o I dont know if something is buggy there.. And Yes Im constantly Logged In..
geposted Sat 17 May 14 @ 10:24 am
