If you are using iWall Text 2 Screen software, I need your help. The current version does not work with Virtual DJ Pro 8. It use a free frame plugin, which connect its software to Virtual DJ. I reached out to the developer to update his plugin to support Virtual DJ Pro 8 to no avail. If I have other users, I can persuade him to develop an upgrade which will take an hour of his time based on my own developer for a separate business I own. He said it is best if he upgrade to free frame 1.5 but only the developer has the source codes and there is no API available to interface the two programs. It is a great tool if you are a DJ who play videos and/or karaoke. If you are an iWall user, please list yourself here so I let him know. Thanks!
geposted Sat 17 May 14 @ 1:33 pm
Hi there,
I use Iwall but havent used it in a while as I have been using IMU pangolin which works with VDJ8.
I will send an email to Francisco the developer to see if support and development is to continue for the plugin.
Mark
Mark
geposted Thu 14 Aug 14 @ 2:25 pm
