Here are the issues encountered so far:
BUGS:
1. Can't turn off auto pitch (auto sync). options say they are off but still adjusts the pitch automatically.
2. Can't access the drop down menu for the effects panel on the right deck, i' locked out of it. Left deck is fine but no drop down list of the effetcs on the right. The icon is there but no reaction when the button is clicked.
PERSONAL ISSUES:
1. Quick Video linking with drag and drop is essential for quick addition of visuals and videos to tracks with none. Video editor is great but really need and on the fly option.
2. Cue doesn't snap to preset first cue point as before (small issue)
Thanks for the hard work guys.... so far so good.
BUGS:
PERSONAL ISSUES:
geposted Sat 17 May 14 @ 4:50 pm
Pointless posting if these things get ignored. Hope its ready someday. Keep up the good work guys.
geposted Fri 23 May 14 @ 6:52 pm
Have you switched off autoBPMMatch
Your cue issue - is that when you load a track?
autoCue - change to cue
geposted Fri 23 May 14 @ 7:09 pm
Can you explain this a bit more ? What happens if you click on the read arrow button on the right deck, right next to the Effect trigger button ? Would a screenshot help ?
geposted Sat 24 May 14 @ 1:06 am
