Topic: SCRATCH WAVE FORMS AND VU METER
DJ KyriPRO InfinityMember since 2006
I Started a Topic before I have no Idea where it went.. but here it is again.. a little shorter this time..
Scratch Waves are gone for some reason.... and Default wave forms are dark????? is this a bug or setting somewhere that i switched by accident...???
Also.... deck A is Blue on the vertical UV meter.. deck B is Red until the tipy top and it show yellow...... WHy only on deck B and not A???
geposted Sat 17 May 14 @ 5:04 pm
did you turn off hardware acceleration for skin in options?
what graphic card you have?
geposted Sat 17 May 14 @ 5:09 pm
Also what skin are you using? Some old skins dont play nicely with VDJ 8.
geposted Sat 17 May 14 @ 5:59 pm
