Hello,
I just wnat to know if there is anyway to use ipad as webcam to active camera 8 plugin
geposted Sat 17 May 14 @ 6:27 pm
yes you can use pocketCam on your iPhone or iPad. you must load pocket Control on your mac first. Make sure you downloaded the plug-in for camera on virtual DJ. okay here's the order to do.
First open Virtual DJ
After you configure everything that you normally use.
Open pocket control on your computer. start the app on your phone called pocket cam.
You have to make sure that the phone or iPad is on the same Wi-Fi is your computer.
Virtual DJ Go into effects. video. look for camera.
When you open up camera in the effects window there's a slider at the top right-hand side slide it to the right until you find the camera or phone that you wanted to use
geposted Mon 02 Jun 14 @ 6:39 pm
Is there any way to do this from a pc?
geposted Mon 29 Dec 14 @ 5:51 pm
Yes this also works on a PC with an Ipad, IPhone or Itouch................
geposted Thu 08 Jan 15 @ 12:20 am
I ant find the plug in for pc. Whats it call and under what section can I find it ? Ty
geposted Thu 24 Sep 15 @ 6:45 pm
someone found pc plugin, please?
geposted Wed 26 Oct 16 @ 8:15 am
