WHY does the software keep crashing ?!!!
i have a 2013 Macbook book pro Retina display and ten minutes into my mix it crashes and then freezes!
ITS STARTING TO GET ME VERY MADDDDDDDD!!!
i updated everything on my computer! Shoot to make things worse i tried my friends Itch program to see if mabe its the computer
and it worked FLAWWWLESS
PLEASE I NEED HELP ASAPPPPPPP!!!1
geposted Sat 17 May 14 @ 8:43 pm
Have you logged into the software using you forum details?
geposted Sat 17 May 14 @ 8:53 pm
crash : win 8.1 64bit
- System
- Provider
[ Name] Application Hang
- EventID 1002
[ Qualifiers] 0
Level 2
Task 101
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-05-18T00:09:54.000000000Z
EventRecordID 19639
Channel Application
Computer Virtual-DJ
Security
EventData
virtualdj8.exe
8.0.0.1765
1d00
01cf7204fc5ba95c
79
C:\Program Files (x86)\VDJ8\virtualdj8.exe
5929e3da-de20-11e3-bed6-6036dd92547c
55006E006B006E006F0077006E0000000000
Binární data:
Ve slovech
0000: 006E0055 006E006B 0077006F 0000006E
0010: 0000
V bajtech
0000: 55 00 6E 00 6B 00 6E 00 U.n.k.n.
0008: 6F 00 77 00 6E 00 00 00 o.w.n...
0010: 00 00 ..
- System
- Provider
- EventID 1002
[ Qualifiers] 0
Level 2
Task 101
- TimeCreated
EventRecordID 19639
Channel Application
Computer Virtual-DJ
Security
EventData
virtualdj8.exe
8.0.0.1765
1d00
01cf7204fc5ba95c
79
Binární data:
Ve slovech
0010: 0000
V bajtech
0010: 00 00 ..
geposted Sat 17 May 14 @ 11:06 pm
Yes it I signed in and still same issue
geposted Sun 18 May 14 @ 12:04 pm
You need to give more information about exactly what you're doing before (or when) it crashes.
Are you using audio or video? Are you using a controller? Which one? Internal or external audio interface? Which one?
Is the media you're playing on an internal drive or external?
Are you using a second screen? Are you broadcasting or recording?
As much info as possible please.
geposted Sun 18 May 14 @ 12:13 pm
