Ok, I know its bad juju to remove the VDJ Logo from the video output screen...but, why does it have to be so big? Is there an option to change the size? If not, can it be turned off, as in VDJ 7?
geposted Sat 17 May 14 @ 9:37 pm
There are options to both make it smaller and turn it off. I don't remember what they are but you can go to config and in the search box type video. You should be able to see the options.
geposted Sat 17 May 14 @ 9:39 pm
Aaaah....found it. But you have to make sure to check the "show advanced settings" box.
Thx!
Thx!
geposted Sat 17 May 14 @ 10:04 pm
The sad thing is that I paid a controler version of VDJ8 and the option to move or change the logo is OFF....
geposted Thu 05 Jun 14 @ 8:18 pm
As stated on this page link the "controllerist" license is for advanced home users and not for use professionally. It states that if you are earning money with VDJ then you need to purchase a Pro license.
geposted Fri 06 Jun 14 @ 4:18 am
the request for switching off the logo does not assume a proffessional use inevitably i guess...;-)
geposted Fri 06 Jun 14 @ 5:03 am
