Topic: USB Headset
Hi Guys
Just a quick question.......for my radio shows I use a usb headset with built in mic, in version 8 the mic sounds robotized voices but if I enable Asio voice sounds fine over the mic although it then gives me audio drop outs when playing music, this is still the case with wasapi, ultra latency and overclock set to on or off.
Im using windows 7 ultimate 64bit
Any ideas?
Cheers Dan
geposted Sun 18 May 14 @ 8:32 am
