The jog display stands still only the lighting goes.
When the play button 2 x presses the song is playing out slowly.
Scretchen and regulate speed by also is not the jog.
I hope understand what I mean. My english is not so good.
geposted Sun 18 May 14 @ 9:12 am
For the first issue , yes, it is a known bug. Hopefully fixed soon.
But cant really understand what the other issues are. Could you make a video and post the link here ?
Are you on windows or Mac ?
geposted Sun 18 May 14 @ 1:56 pm
Thanks for the quick reply.
I use a Mac
I'll try to explain the 2 times a problem.
If you press the Play button in the 2000s two remaining are the song and I can look out with the jog me beat.
When I try this with VDJ8 the song runs at 2 times the song is langsama and running out. Is like the Techniks phonograph if I make it out.
I hope you understand what I mean, if not I still have to make a video.
I use a Mac
geposted Mon 19 May 14 @ 4:17 am
we tryed yesterday the sz
we used a mbp 13 with i7 2,5ghz 16 gb ram macosx 1.8.x and bootcamp win 7!
vdj8 1774
clean V8 install (no V7 files)
in mac the program crashed with the SZ and after restarting 3 times it becomes unresponsive (had to turn the mac off)
in win V8 and SZ works out off the box so far
testing is ongoing
vdj8 1774
testing is ongoing
geposted Mon 19 May 14 @ 4:53 am
Thanks for the infaormation.
I have a Mac Book pro 15 "i7 2.2GHz 8GB Ram, Mac OS X Lion 10.7.5 and Paralles also runs with win7 64bit. VDJ8 I have installed next VDJ7 crashes when testing VDJ8 I had not. Only after VDJ8 had uninstalled it was crashing on Mac had him with the power button from make.
Thereafter, however, went VDJ 7 no longer correct. I had to put out a hedging copy the VDJ7 folder restores.
geposted Mon 19 May 14 @ 7:04 am
will give you the answer in the german forum
geposted Mon 19 May 14 @ 7:31 am
Gerry ...if there is a solution for this issue it might be useful to have the answer also here, so everyone can benefit from what you found out ....
geposted Mon 19 May 14 @ 7:45 am
it is gerrit not gerry by the way
i have posted the solution also here in the beta forum severaltimes
atomix desided not to split the Vitualdj folder under dokuments
that leeds to problems when you going back and force with v8 and v7 (its by design)
the workaround is for windows simple
make a copy of vdj7 Virtualdjfolder
go to the regestrie and change the "homefolder" to the right virtualdj folder under documents
than start V8 or V7 and you have no problems reverting back to v7 or testing V8
geposted Mon 19 May 14 @ 8:11 am
Sorry for the missing "t" ...;-)
geposted Mon 19 May 14 @ 8:16 am
name is program you missed also the i (it) ;-) LOL
geposted Mon 19 May 14 @ 9:32 am
thought should left a letter left for you....LOL...
BTT please...;-)
BTT please...;-)
geposted Mon 19 May 14 @ 9:35 am
Hello,
Thanks for the tip only I use Mac OSX.
If I've understood correctly I rename the folder in Documents to VDJ7 easy. And install as VDJ8. If I then uninstall VDJ8 wiedr I bennene the folder VDJ 7 to again and everything should work again?
geposted Tue 20 May 14 @ 2:32 am
yes thats how it works but don't start V7 wile V8 is on your Mac Or rename the V8 Folder
geposted Tue 20 May 14 @ 3:34 am
Hello,
Could someone give here tell me about it. VDJ8 if it works well with the ddj sz and a Mac?
geposted Wed 21 May 14 @ 9:50 am
MAc Version, its in work...
geposted Wed 28 May 14 @ 4:10 am
