Topic: HC4500 [SOLVED]
all is working great just cant get the info to show on the hc4500
geposted Sun 18 May 14 @ 12:19 pm
It works OK here. Are you using the latest firmware (as Denon would say)?
PC or Mac?
geposted Sun 18 May 14 @ 12:22 pm
Think so I will look I'm using a mac
geposted Sun 18 May 14 @ 2:08 pm
my 4500 isnt displaying text either
geposted Wed 21 May 14 @ 1:05 pm
Mac? PC? Operating system? HC4500 firmware version?
geposted Wed 21 May 14 @ 1:08 pm
Should be fixed in build 1819
geposted Thu 29 May 14 @ 2:34 pm
Go to config > Controller > HC 4500 and make sure controller is enable . I had the same issue but it's fixed now. Good Luck!
geposted Fri 30 May 14 @ 1:55 am
I never had any prob´s since the early betatimes with the HC 4500
geposted Sat 31 May 14 @ 6:16 pm
mine wasnt working intially but since an update saturday the text now works... i didnt even notice until the light jock said :-)
geposted Sun 01 Jun 14 @ 12:35 pm
