Topic: Previewplayer don´t play Sampler BUILD 1774
metrixPRO InfinityMember since 2007
Previewplayer don´t play Sampler. If i turn it on and change to the other Samplers Previewplayer crashed
Sampler are 0:05 mp3
geposted Sun 18 May 14 @ 12:22 pm
leneerPRO InfinityModeratorMember since 2014
Check your audio config's sound card. For example:ASIO Buffer
geposted Sun 18 May 14 @ 12:57 pm
Why are you posting these pictures everywhere??
geposted Sun 18 May 14 @ 1:19 pm
I can play 8 Sampler and then it stop´s playing
ASIO Buffer is on 12-32 its change nothing
geposted Sun 18 May 14 @ 1:32 pm
It works OK for me.
What format are your samples?
16 bit/24 bit/44.1khz/WAV/MP3?
geposted Sun 18 May 14 @ 1:44 pm
i have mp3 wav and vdj
mono 8000hz 32bit
stereo 22050 32 bit
mono 22050
stereo 44100 32bit
everyone sampler is different maybe thats the problem
geposted Sun 18 May 14 @ 2:03 pm
