Topic: DENON SC3900 - Hybrid Mode
Hi everybody,
Impossible for me to use DENON SC3900 in hybrid mode.
Problems : when i play a track, then sound "freeze" every 2 or 3 seconds
What is the right config to use it ?
I'm on Mac, with a SL3 Soundcard.
Thanks
geposted Sun 18 May 14 @ 1:34 pm
did you find a fix? I can not get mine to work at all
geposted Fri 30 May 14 @ 10:41 pm
geposted Fri 30 May 14 @ 11:54 pm
If you set the MIDI mapping to ignore in v8 does the problem go away for you?
I'm not saying this is the fix BTW, just a test :)
geposted Sat 31 May 14 @ 4:09 am
Could you please try to test again with the latest build and report back of any issues left ?
thank you
geposted Tue 23 Sep 14 @ 12:41 pm
