Topic: Update build 1774 failed again
Automatic update from build 1761.645 up to build 1774 failed.
Error message: VirtualDJ automatic update failed, do you want to try again?
I tried again and again over hours without success....
geposted Sun 18 May 14 @ 3:17 pm
If you reboot your machine will it update then?
geposted Sun 18 May 14 @ 3:19 pm
It worked. It's so simple as that
...sometimes. Not a clue what caused this update problem.
geposted Sun 18 May 14 @ 4:35 pm
You shouldn't need to reboot really - but at least it saves all the hair pulling and frustration.
geposted Sun 18 May 14 @ 4:37 pm
