Topic: Search Problem...
How come when I type in "Frank S" I get results like Frankie Yankovic, Frankie Valli, etc... This doesn't look like "Frank S" to me.
geposted Sun 18 May 14 @ 4:43 pm
What search criteria do you have active? Just artist or artist and title?
If you have the latter - then if there is an "s" in the title then it will display.
geposted Sun 18 May 14 @ 4:47 pm
Dan, where is the search criteria? I did a search in the options and could not find when searching for "search".
geposted Sun 18 May 14 @ 4:53 pm
Got it.. thanks!
geposted Sun 18 May 14 @ 4:55 pm
For reference: normally when you search 'Frank S' it will look for Frank anywhere in track or artist and S too.
If you need to search more specifically use "
so in your example "Frank S" (with the " will search for just that and not anything simply containing parts of what you search.
In other examples.. If you're searching for Amy Winehouse - Valerie you could simply just cut it down to 'wine val' (without the ' )
OR if you simply just wanna see just the songs by Amy Winehouse use "Amy Winehouse" (With the " )
geposted Sun 18 May 14 @ 7:34 pm
