I have issues with the cues on denon mc6000 on vdj7
When I set a cue on a song it would save as hot cue #1 on vdj8 it only sets the cue And it does not save it on the cue banks also I was recording an audio gig and while I was playing it sound perfect but when I listened to the recorded file there was distortion on the audio any suggestions.
geposted Sun 18 May 14 @ 7:52 pm
Before recording, did you properly stage your gains? I'm guessing your gains may be high causing the distortion.
geposted Sun 18 May 14 @ 8:58 pm
I use internal mixing and I set the gains at 50% but I did noticed that the gain lights were at peak . Also the master was set at 40% so there is no way it was clipping. Any suggestion on the cue hot to auto save as hot cue as vdj7 thanks
geposted Mon 19 May 14 @ 1:32 am
Even on internal mix, your inputlevel could be set too high in your internal soundcard-settings. Even with reduced gains, your input could still be too loud for your card.
Open your Windows-mixer (System tray, right-click on the speaker-symbol, choose Recording devices) and check, with VDJ running, if your input level isn't too high. The VU-meter in the Windows-mixer gives you a good impression.
geposted Mon 19 May 14 @ 4:58 am
Hi I know my English is not real good and I did not explain my self very well. The vu meters on vdj8 mixer keep reading high even at low gain settings I have the setting at auto gain only. Also please how can I set my cue to auto save as hot cue as it does on vdj7 please read first message thank you
geposted Mon 19 May 14 @ 11:40 am
Also the distortion sound was like when you have a loose speaker wire and just keep making ground noise
geposted Mon 19 May 14 @ 11:43 am
So it's a hum or buzz, not distortion (overload)?
Maybe it's ground loop issue or computer PSU noise.
geposted Mon 19 May 14 @ 11:49 am
I did not have this issue with vdj7 any help with cue settings please
geposted Tue 20 May 14 @ 10:40 am
