Hi there,
Using VDJ 7.4.1, the normal action for the Loop Parameter knob was that, when a loop is active, turning the knob one "click" right would make the loop twice the size (double) and turning it left one "click" made the loop half the size (half).
In VDJ8, ANY turn of the parameter knob HALVES the loop....(both right OR left). The mapping to this knob is as follows:
param_greater 0% ? loop_half : loop_double
Did something change in VDJscript or is this a bug in the code?
Thanks!
Nick
Thanks!
Nick
geposted Sun 18 May 14 @ 8:40 pm
If its an endless encoder these should work..
param_greater 0 ? loop_double : loop_half
or simply ..
loop_double
Btw, the knob is mapped as loop_double in the default mapper. Doesnt it work for you ?
or simply ..
loop_double
geposted Sun 18 May 14 @ 9:05 pm
or simply ..
loop_double
or simply ..
loop_double
I am using a custom mapper from 7.4 but I don't remember EVER changing this setting. I did try both of yours listed above and whaddya know!! The default setting of "loop_double" worked like a charm to restore the proper action.
Thanks DJDAD!
geposted Sun 18 May 14 @ 9:12 pm
