Topic: jog sensitivity bend
I want to adjust the pitch bend on my jog wheels so that they are not so sensitive.
I read in another post that I need to adjust the jog sensitivity bend command, but I can't find it, and I don't know what to do with it when I do.
I am running a Denon mc-6000
Thanks.
geposted Mon 19 May 14 @ 5:42 am
Click Show Advanced Options and type sensitivity in search box. 0.030000 works well
geposted Mon 19 May 14 @ 7:11 am
