Topic: virtual folder ver8
Does anybody has issue trying to arrange sub virtual folders or is it just me?
http://youtu.be/NsCqVDQVGUI
And another thing is that many many tracks being on database and are present in ver7 doesn't show up on ver8.
Ps. ver8 added a new virtual folder in my browser with the ending .vdjfo
So no i have an empty "early" and a new "early.vdjifo" who has the subfolders.
when i tried to delete the original and rename the other without .vdjifo i lost subfolders
when i re-open the program "early.vdjifo" is present again with all the subfolders....
geposted Mon 19 May 14 @ 9:38 am
gbeulPRO InfinityMember since 2007
i gues the problem is during migration
first look in the Virtualdj Folder under Dokuments
there must be an Folder called "Folders"
here all Vitrual-Folder/Dynamic Folder and Favorite Folders Placed
Virtual Folders are Folder
Dynamic Folder are XML Files
Favorite Folder are XML Files
The same Structure is also in every external media
geposted Mon 19 May 14 @ 9:49 am
So i went into this folder and i see only a folder named music (fg) wich is empty and a xml file called order.
In external media i get more virtual folders (maybe all) but i still don't understand what i have to do to re-arrange them
Thanks for your answer anyway
geposted Mon 19 May 14 @ 10:03 am
virtual folder (the red ones) are folders within the folder "folders" in virtualdl /folder
if you move the xml files to this struckture you can arange and sort it offline (close v8 move xml start v8)
in v7 all the folder were in the database file in virtualdjvolder (username/documents)
with the migration the folder now whent to the drive were they belong to be (eg your externaldrive)
geposted Mon 19 May 14 @ 12:43 pm
i am greatful to you for your answers but i really don't understand!!!
geposted Tue 20 May 14 @ 10:16 am
