Topic: History... What happened?
DJ KozPRO InfinityMember since 2007
After VDJ8 changing the sort for History, it doesn't show my playlist for this past weekend. What happened? I am on a Mac using Mountain Lion.
geposted Mon 19 May 14 @ 10:14 am
Numerous threads on this already but you have to copy your history into the new history folder.
geposted Mon 19 May 14 @ 10:22 am
This has been changed several builds ago, and the installer now copies your Tracklisting folder to the new History one when you install VirtualDj.
But apprently, this wont happen if you had the software installed already and you simply accept the updated builds.
In that case, yes, all you need to do is to manually copy and paste the files from your Tracklisting folder to the History one and relaunch.
geposted Mon 19 May 14 @ 10:25 am
OK I will do that. Thanks.
geposted Mon 19 May 14 @ 11:09 am
Where is the 7.4 history folder? in V8, my playlists are there but no history except the new V8 history...
geposted Mon 19 May 14 @ 11:36 am
V7 doesn't have a "History" folder.
In v7 these files are located in the folder named "tracklisting"
geposted Mon 19 May 14 @ 11:45 am
I had a thing in VDJ called HISTORY... Didnt know it was the folder TRACK LISTING...
geposted Mon 19 May 14 @ 11:55 am
