Topic: Audio 8 Timecode
Cannot get VDJ 8 to work with timecode CD under Audio 8 soundcard, get a signal but of of the messages for detection reads "No Position" under the timecode settings. Any suggestions.
geposted Mon 19 May 14 @ 10:55 am
Are you on a Mac or PC?? I ask because I had the same thing happen but only on the Mac side.
geposted Mon 19 May 14 @ 11:19 am
PC Side, Windows 7
geposted Mon 19 May 14 @ 4:28 pm
eljurrel wrote :
reads "No Position" under the timecode settings. .
did you select the correct timecode engine, corresponding to your vinyls/cds ?
geposted Mon 19 May 14 @ 4:40 pm
It's clear in VDJ 7, but I could not find the mode in 8. Should be obvious to me but it did not stand out to separate vinyl and Cd mode. I am looking for CD mode for VDJ CD timecode.
geposted Mon 19 May 14 @ 4:46 pm
