Topic: Scratching
I noticed when scratching my channel runs into the red all the time , I don't know if this is a issue or not . Just never happened in 7.4
geposted Mon 19 May 14 @ 11:23 am
I have. It seems like VDJ8 raises the gain of the channel while i am scratching. It is weird
geposted Mon 19 May 14 @ 2:46 pm
So did we find out if this is a problem , I also noticed the limiter light comes on every time you scratch also
geposted Tue 20 May 14 @ 12:57 pm
this should be fixed in latest update, the scratch loudness that is.
The limiter red light will probably still come on, as naturally the peaks are more intense and overloaded at scratching (not to worry about the red light)
geposted Tue 20 May 14 @ 1:22 pm
