Forum: VirtualDJ Skins
Topic: VirtualDJ 8 - Controller by DennYo - Page: 13
HKashPRO InfinityMember since 2013
HKash wrote :
Hey gang. Weird issue.
First off, Laptop is plenty powerful and dedicated. (no extraneous software or Porn, lol)
Second, Denon DN MC6000mk1 controller.
3rd - Virtual DJ full Pro using 8
Recently switched to the "Controller by Dennyo" skin and was loving it. Seems lately, my right virtual player stops communicating with my denon while playing video. (The video continues to play along with the audio). I can still manipulate the waveform and cue, play pause everything on the laptop with a mouse) but it seems like the denon disconnects. I've reverted back to the default VDJ 8 2 deck skin and am running the heck out of it...no issues as of yet. Anyone else having issues with "Controller by Dennyo" 2 deck w/ video skin? (I hope it's simply an update or something, I really love the skin) Any suggestions?
geposted Thu 26 Feb 15 @ 7:25 am
HKash wrote :
.....Anyone else having issues with "Controller by Dennyo" 2 deck w/ video skin?
No problems at all, but I use 4 decks video. What happens if you use 4 deck?
geposted Thu 26 Feb 15 @ 7:29 am
ProfLeePRO InfinityMember since 2011
No problems here. You say you have reverted to the default skin and have no issues. Have you tried any other skins to see if you can replicate the issue?
If yes to the above,
Try reverting VDJ8 back to factory then re-download and install a fresh copy of Controller? It could something as simple as a bad zip file of bad skin install.
geposted Thu 26 Feb 15 @ 3:21 pm
Haven't tried 4 deck. I have no reason to use it. I'd prefer to just get the 2 deck working. lol.
geposted Fri 27 Feb 15 @ 8:18 am
Well, I haven't really messed around with too many skins. I've seen (On the boards) issues with different skins causing....well...."Issues". lol. "Controller" caught my eye due to several things and I gave it a shot. I have a full weekend (andd Week) of gigs coming up, but will try to re-install "Controller" after that. (Don't like to make any changes "Under the Hood" before events.) I'll just stick with default for now. Thanks for the input all!!
geposted Fri 27 Feb 15 @ 8:22 am
@HKash
I wonder if this might be related to the issue I had a while back*, when I discovered that the 2 deck skins should actually have been set to 4 decks in the XML.
If I remember correctly, the MC-6000 needs a 4 deck skin - so if the code for nbdecks in the XML is set to 2, either delete that statement or change it to nbdecks="4" and see if that solves things.
* page 10 of this thread, 5th post
geposted Fri 27 Feb 15 @ 8:24 am
I remember Denny said, that he wanted to put as little functionality into the skin as possible.
Meaning, most controller mappings already have an unload option. And the Skin is developed for controller use.
So, no need for the skin to handle that.
geposted Fri 27 Feb 15 @ 8:57 am
4.1.4 Update
-Add new Player Background
-Add an colour line behind the Pitchfaders
-Add Values to the Effect Sliders
-little Bugfixes
geposted Mon 02 Mar 15 @ 1:54 pm
hi Denny
when will you add a multi fx ,instead of only one ?
geposted Mon 02 Mar 15 @ 3:53 pm
Aww...I was hoping for overlapping wave forms. Will that be in the next release?
geposted Tue 03 Mar 15 @ 7:28 am
Hi, Sorry if this is a duplicate. I thought this was posted. Will the ONINIT command (left from previous versions) cause the program to crash?
geposted Thu 05 Mar 15 @ 12:52 pm
With the next Update comes overlap Wave on the TopWave variation.
romeodan wrote :
hi Denny
I will add multi fx on the next Update ;)
_____
But i don't have any time at the moment.
geposted Fri 06 Mar 15 @ 4:40 pm
Nope. But I can't think of a good reason to leave it set to duplicate what the skin now does as a selectable option.
geposted Mon 30 Mar 15 @ 10:40 pm
jbezzPRO InfinityMember since 2010
Was wondering if you had any plans for overlapping waveforms on this great skin?
geposted Fri 17 Apr 15 @ 9:57 am
Look up (two posts above yours). :-)
geposted Fri 17 Apr 15 @ 11:41 am
geposted Mon 05 Oct 15 @ 1:13 pm
This very good skin gives a problem with the latest build. I always have a grey box.
geposted Tue 06 Oct 15 @ 1:01 pm
espepePRO InfinityMember since 2009
Me too that guay box is very annoying
geposted Sun 11 Oct 15 @ 7:40 am
Solved again in the latest build. Nice and fast work from the staff!
geposted Mon 12 Oct 15 @ 6:52 am
Solved too Thanks .......
geposted Wed 14 Oct 15 @ 5:57 pm
73%
