Hello
I ihave a lot of transition edits of songs which have two different tempos. For example I am using a track that goes from 128 bpm down to 95 bpm. I added a beatgrid anchor with a new bpm value 95 and it works farly well. I can sync another deck with this new bpm. The problem is that it is not very intuitive. Only extra grids get aligned with new bpm, the deck still shows the original 128 bpm value. Also if I altern the tempo it shows original value shifted. Oh and one more thing. I always use filter folders with certain bpm difference value, they dont work. Now the filter folder with bpm difference < 10 should show tracks that have bpm range 85-105 but it still shows 118-138. In perfect software it would update values, filter folters etc automatically depending on which part of the song is playing. That would be intuitive. Thanks!
geposted Mon 19 May 14 @ 3:48 pm
