Topic: Audio Video selection
Sound
*V7 Select soundcard or hdmi from within VDJ Software ... Easy
*V8 No selection of soundcard within software need to disable "speakers" and enable "HDMI" Sound in laptop software ...... Messy
If its not right (freezing) then I need to reset sound in VDJ to something else then rest it back to work.
Video
selection works not sure if out v7 method was not better.
Video seems to be freezing for sec or so every min or so, never used to do this until testing current 1781 build, new files this time from personal video, but never had this problem with these files before,
and work perfectly in MPC player.
geposted Mon 19 May 14 @ 7:09 pm
