Topic: Old effects not appearing
Hey, I just downloaded VDJ 8 and it rocks, but my favorite effect "TK Filter V2" doesn't seem to work. Is there any way I can fix that?
geposted Tue 20 May 14 @ 4:19 am
If you are able to write plugins, yes, you could wirte your own filter for v8.
If not, then no. Unless the creater of the plugin ports it to v8.
geposted Tue 20 May 14 @ 4:25 am
A lot of version 7 (or earlier) plug-ins are incompatible with version 8. All known incompatible plug-ins have been disabled.
If the author of the plug-in updates it to become compatible with version 8 then it will appear on the list again.
geposted Tue 20 May 14 @ 4:29 am
