Hi Team
I have been trialing the key change functionality however it does not seem to reset when you push = and if change more than 3 semitones in either direction it appears to stick and will not reset.
It will only reset /if you stop the track and reload it.
No good for Karaoke key changes on the fly.
geposted Tue 20 May 14 @ 4:39 am
Thank you for noticing. It will be fixed.
Actually what the = button does is to match the Key of the track with the Key of the opposite deck.
geposted Thu 22 May 14 @ 3:23 am
Thanks djdad,
Need to change that in the manual then....
Is there space for a reset then please since = does not do this.
geposted Thu 22 May 14 @ 7:05 pm
